این کانفیک سویچ core شبکه من هست
hostname SW-000 ! ! ip dhcp pool Two network 192.168.20.0 255.255.255.0 domain-name Varastegan.ac.ir dns-server 192.168.0.6 192.168.0.7 default-router 192.168.20.254 lease 5 ! ip dhcp pool Tree network 192.168.30.0 255.255.255.0 domain-name Class.Varastegan.ac.ir dns-server 4.2.2.4 8.8.8.8 default-router 192.168.30.253 lease 0 1 ! ip dhcp pool Four network 192.168.40.0 255.255.255.0 domain-name Class.Varastegan.ac.ir dns-server 4.2.2.4 8.8.8.8 default-router 192.168.40.253 lease 0 1 ! ip dhcp pool Five network 192.168.50.0 255.255.255.0 domain-name Site.Varastegan.ac.ir dns-server 4.2.2.4 8.8.8.8 default-router 192.168.50.253 lease 0 1 ! ip dhcp pool Six network 192.168.60.0 255.255.255.0 domain-name Site.Varastegan.ac.ir dns-server 4.2.2.4 8.8.8.8 default-router 192.168.60.253 lease 0 1 ! ip dhcp pool Seven network 192.168.70.0 255.255.255.0 domain-name Wifi.Varastegan.ac.ir dns-server 4.2.2.4 8.8.8.8 default-router 192.168.70.253 lease 0 1 ! ! interface GigabitEthernet1/0/1 switchport mode trunk ! interface GigabitEthernet1/0/2 switchport mode trunk ! interface GigabitEthernet1/0/3 switchport mode trunk ! interface GigabitEthernet1/0/4 switchport mode trunk ! interface GigabitEthernet1/0/5 switchport mode trunk ! interface GigabitEthernet1/0/6 switchport mode trunk ! interface GigabitEthernet1/0/7 switchport mode trunk ! interface GigabitEthernet1/0/8 switchport mode trunk ! interface GigabitEthernet1/0/9 switchport mode trunk ! interface GigabitEthernet1/0/10 switchport mode trunk ! interface GigabitEthernet1/0/11 switchport mode trunk ! interface GigabitEthernet1/0/12 switchport mode trunk ! interface GigabitEthernet1/0/13 switchport access vlan 10 switchport mode access ! interface GigabitEthernet1/0/14 switchport access vlan 10 switchport mode access ! interface GigabitEthernet1/0/15 switchport access vlan 10 switchport mode access ! interface GigabitEthernet1/0/16 switchport access vlan 10 switchport mode access ! interface GigabitEthernet1/0/17 switchport access vlan 10 switchport mode access ! interface GigabitEthernet1/0/18 switchport access vlan 10 switchport mode access ! interface GigabitEthernet1/0/19 switchport access vlan 10 switchport mode access ! interface GigabitEthernet1/0/20 switchport access vlan 10 switchport mode access ! interface GigabitEthernet1/0/21 switchport access vlan 10 switchport mode access ! interface GigabitEthernet1/0/22 switchport access vlan 10 switchport mode access ! interface GigabitEthernet1/0/23 switchport mode trunk ! interface GigabitEthernet1/0/24 switchport mode trunk ! interface GigabitEthernet1/1/1 ! interface GigabitEthernet1/1/2 ! interface GigabitEthernet1/1/3 ! interface GigabitEthernet1/1/4 ! interface TenGigabitEthernet1/1/1 ! interface TenGigabitEthernet1/1/2 ! interface TenGigabitEthernet1/1/3 ! interface TenGigabitEthernet1/1/4 ! interface Vlan1 ip address 192.168.150.1 255.255.255.0 ! interface Vlan10 ip address 192.168.0.1 255.255.255.0 ip policy route-map 10 ! interface Vlan20 ip address 192.168.20.1 255.255.255.0 ! interface Vlan30 ip address 192.168.30.1 255.255.255.0 ! interface Vlan40 ip address 192.168.40.1 255.255.255.0 ! interface Vlan50 ip address 192.168.50.1 255.255.255.0 ! interface Vlan60 ip address 192.168.60.1 255.255.255.0 ! interface Vlan70 ip address 192.168.70.1 255.255.255.0 ! route-map 10 permit 10 set ip next-hop 192.168.0.254 !
اینم طرح مفهومی اون هست
من که کامپیوترم روی vlan 20 هست نمیتونه سویچ های دیگه که همه توی رنج 192.168.150.X هستن رو ببینه
بنظزتون کجای کارم مشکل داره
نکته:
- من یه سویچ 3580 و 12 تا سویچ 2960 دارم که همه از طریق trunck به هم متصل شدن
- دو تا از vlan های من ( سرور ها و کلاینت های جوین شبکه ) از کریو به عنوان روتر استفاده می کنن و باقی vlan ها از میکروتیک به عنوان روتر استفاده میکنن
